playback inconsistent sound
randaws
Post by randaws » Wed Jul 13, 2016 3:15 am
I have the 2.1.2 version with .exe installer when I playback a track it sounds okay for the first bar or so and starts fading in an out with a weird phasing effect..can anyone tell me how to remedy this?
Re: playback inconsistent sound
Post by steve » Wed Jul 13, 2016 10:31 am
randaws wrote: when I playback a track it sounds okay for the first bar or so and starts fading in an out with a weird phasing effect.
Is that a track that you've recorded, or one that you've imported?
If you generate a 30 second tone (Generate menu > Tone), does that play correctly (as a constant tone)?
If it's a recording that you have made, how did you record it, what equipment are you using, and how is it connected together?
I'm guessing that it's a recording that you have made, and that Windows is messing with the recording level, as described here: http://manual.audacityteam.org/man/faq_ ... hancements
Another possibility is that if you have Skype running in the background while you are recording, that can mess with the recording.
