audacity isn't recognizing java
yugioh47
Post by yugioh47 » Tue Jul 12, 2016 3:17 pm
hi, i've got the message that a plugin that use's java and audacity isn't recognizing java's path's. can you tell me why?
Audacity_dbgrpt-8676-20160712T105258.zip
(83.89 KiB) Downloaded 24 times
DVDdoug
Forum Crew
Re: audacity isn't recognizing java
Post by DVDdoug » Tue Jul 12, 2016 6:08 pm
I'm not a developer but as far as I know, Audacity has no relationship to Java.
Do you have a Java plug-in that's supposed to work with Audacity?
yugioh47
Post by yugioh47 » Tue Jul 12, 2016 8:20 pm
DVDdoug wrote:I'm not a developer but as far as I know, Audacity has no relationship to Java.
yes i've got a java plug-in that's suppose to work.
these are the ones that i'm have trouble with audicity. before they worked on audacity. http://www.pitchtech.ch/Plugins/
Post by Gale Andrews » Wed Jul 13, 2016 2:04 pm
yugioh47 wrote:these are the ones that i'm have trouble with audicity.
Those plugins work for me in Audacity in 2.1.3-alpha on Windows 10, so it is a problem with your JAVA environment.
Also make sure you copied the plugins' three .jar files into the folder where you installed the plugins.
yugioh47
Post by yugioh47 » Wed Jul 13, 2016 9:53 pm
ok i'll try that
