Convert MP3 to text
Welsh_John
Convert MP3 to text
Post by Welsh_John » Fri Jul 08, 2016 1:31 pm
Hi
I am almost 70 and not very computer literate. I have some MP3 voice files which I would like to convert to text. I have searched with Google and one answer was to use Audacity. However, I have looked through the manual and cannot find how to do this. Is it possible and if so how can I do it please?
Thanks
John
Re: Convert MP3 to text
Post by steve » Fri Jul 08, 2016 1:36 pm
No, Audacity can't do that. You need special "speech recognition software", such as "Dragon" (by Nuance).
Post by Gale Andrews » Sat Jul 09, 2016 12:31 pm
Windows (Vista and later) does come with Speech Recognition built in. I don't know how well it works recording a file into a microphone input, but definitely it won't punctuate, so you would have to add punctuation later if recording from a file.
Dragon does have some free trials.
Welsh_John
Post by Welsh_John » Sat Jul 09, 2016 1:21 pm
Thanks Gale and Steve for your replies.
John
