Hey everyone,
I am using audacity program on an acer AS1410 model, with windows 10. audacity version 2.1.2. I am trying to record with a USb condenser mic (Nady USB 1C).
The issues that i am having is that when i press record the recording meter does not move at all. I double checked to make sure that the right mike is selected as default recording device. as well i have read other posts and made sure that sound activated recording is OFF. The recording meter still doesnt move when i press record.
Any help/advice would be greatly appreciated
Thanks
Recording meter line not moving
Re: Recording meter line not moving
It's impossible to get good information on this microphone. Is there a headphone connection on the bottom in addition to the USB? Some microphones have that and it's terrific for troubleshooting—and overdubbing.
http://www.kozco.com/tech/audacity/pix/ ... ctions.jpg
Is there a light that tells you when the USB is connected and working?
Has it ever worked since you took the plastic off? Did the microphone come with a software package?
Info here:
http://recordinghacks.com/microphones/Nady/USB-1C
http://recordinghacks.com/pdf/nady/usb1c.pdf
No headphone port, no software. Just a blue LED. And at least, it shows up as a "Nady USB mic" in the computer and not as something generic and misleading.
Does the cursor move when you hit record?
- Quality Assurance
Also try changing the USB cable and making sure it is tight both ends.
