Audacity stops recording at specific point
aaronnechama
Operating System: Windows 7
Post by aaronnechama » Tue Jul 05, 2016 11:12 pm
I've tried multiple times with the same cassette and each time this occurs.
Using Windows 7, Audacity version 2.1.2, inputting sound from a cassette with a Scarlett 2i2 USB connection. I've used Audacity in the past without trouble, but now the recording suddenly stops at 9:16 for this particular cassette. I don't know if another cassette has a similar problem.
Any ideas?
Re: Audacity stops recording at specific point
Post by kozikowski » Wed Jul 06, 2016 12:50 am
Look at the bottom of the Audacity window and make sure Snap To has not been tuned on.
Also Transport > Timer Record has not been set.
aaronnechama
Post by aaronnechama » Wed Jul 06, 2016 3:13 am
kozikowski wrote:Look at the bottom of the Audacity window and make sure Snap To has not been tuned on.
Negative to both - snap to is set to Off and Timed Recording has not been set.
aaronnechama
Post by aaronnechama » Wed Jul 06, 2016 4:41 am
aaronnechama wrote:I've tried multiple times with the same cassette and each time this occurs.
Any ideas?
I tested it with another cassette and experienced the same problem. Never stops at the same time, although it usually lasts for less than 15 min.
It is a new phenomenon - did not occur in the past.
Post by kozikowski » Wed Jul 06, 2016 5:25 am
Are you running out of hard drive space? If you've been using this software and Win7 for a long time, you could have just run out of space to put new work.
This is a common problem with the video people. "I've been doing production for a long time and today, suddenly, for no reason, it just stopped working."
Post by Gale Andrews » Wed Jul 06, 2016 11:16 am
Connect the USB cable tightly at both ends and shut down the computer. You cannot record from USB devices indefinitely without rebooting.
aaronnechama
Post by aaronnechama » Wed Jul 06, 2016 12:36 pm
kozikowski wrote:Are you running out of hard drive space? If you've been using this software and Win7 for a long time, you could have just run out of space to put new work.
No, it's a brand new computer with 500GB of hard drive space.
I tried recording the cassette into Audacity on another computer, that one is version 2.1.0, and had no trouble at all - the program did not stop at all. Could it be a bug with the current version?
Post by Gale Andrews » Thu Jul 07, 2016 11:32 am
aaronnechama wrote: Could it be a bug with the current version?
Try reading this post above http://forum.audacityteam.org/viewtopic ... 77#p308577.
aaronnechama
Post by aaronnechama » Thu Jul 07, 2016 2:00 pm
Gale,
So if I reboot the computer it should start working again?
That sounds odd.
Post by Gale Andrews » Fri Jul 08, 2016 12:53 pm
aaronnechama wrote:Gale,
That sounds odd.
It's not odd at all, or we would not suggest it.
