Using Audacity with Dazzle Pinnacle
JustCallMeDarth
Post by JustCallMeDarth » Tue Jul 05, 2016 10:52 pm
Like the title says. Dazzle's audio choices kind of suck, there's just nothing there. Downloaded Audacity, but haven't found a way to edit my audio track (my voice, pre-recorded via Pinnacle). I assume this is possible, but lack the expertise. Any help appreciated.
Re: Using Audacity with Dazzle Pinnacle
Post by kozikowski » Wed Jul 06, 2016 12:53 am
In Pinnacle saves your work in a wacky format, you may need to install the FFMpeg software package to open it. FFMpeg's job is to expand Audacity's list of accepted formats.
http://www.audacityteam.org/download/windows/
Scroll down.
JustCallMeDarth
Post by JustCallMeDarth » Thu Jul 07, 2016 12:13 am
kozikowski wrote:In Pinnacle saves your work in a wacky format, you may need to install the FFMpeg software package to open it. FFMpeg's job is to expand Audacity's list of accepted formats.
Scroll down.
Forgive my computer illiteracy, but which one is the FFMpeg?
Post by kozikowski » Thu Jul 07, 2016 2:17 am
We sometimes don't do this in the most straightforward way.
Scroll down until the fourth item in this panel. That will take you to the instructions for downloading and installing.
Screen Shot 2016-07-06 at 7.14.06 PM.png (68.69 KiB) Viewed 239 times
Post by Gale Andrews » Thu Jul 07, 2016 11:58 am
kozikowski wrote:We sometimes don't do this in the most straightforward way.
The most straightforward way IMO is to give the user the direct link to the FAQ: http://manual.audacityteam.org/o/man/fa ... tml#ffdown.
