Making the Voice Sound Better - are there macros?
weiss24
Post by weiss24 » Mon Jul 04, 2016 9:33 pm
I have found a guide called "How To Make Your Voice Sound Better in Audacity" on YouTube, but it takes a while to do everything described. So I wonder, when I've made a recording, are there any macros so this exact thing is done in one-click?
Re: Making the Voice Sound Better - are there macros?
Post by kozikowski » Tue Jul 05, 2016 1:12 am
What's the address?
Did you try it? There's a sharp dividing line between Sweetening and Disaster Recovery. Most people want us to turn their badly recorded voice track into an ACX AudioBook submission. Almost without exception we can't do that and depending on what you did wrong, nobody can.
Let's see what they did.
You can submit a clip of your work and we can usually suggest things to help. ACX AudioBook is a handy measure because they publish a clear list of sound quality standards and we developed "mirror tools" that can tell you what you did wrong without a lot of work.
I'm curious what they published. Fair warning by the time videos make it to You Tube, many of them are for obsolete versions of Audacity and the tools work differently now. It's the main reason Audacity doesn't publish official instructional videos. It's all we can do to keep up with the instruction manual.
weiss24
Post by weiss24 » Tue Jul 05, 2016 7:40 pm
Hi,
Here's the address to the YouTube video with the advice for making the voice sound better on Audacity.
I've done everything, and here is my voice without tweaks, and here it is with tweaks. I think it caused some static, but overall maybe it sounds a little better.
I've just got started with Audacity, and it was last summer I got started practicing English pronunciation. Although I am not making audiobooks, I've got a 200$ gaming mic (Razer Seirēn microphone). I wonder, do "amateurs" who make audiobooks usually have better equipment? What I am aiming for is as good quality as is possible with my current equipment. Maybe I'd get a pop filter later, if that's needed, but it seems my "s"s and "p"s sound okay.
I haven't looked into this post yet, but it seems the claim is that "chains" do the same as macros do in other software.
Post by kozikowski » Wed Jul 06, 2016 1:33 am
At first quick pass I don't hear anything wrong with it, but we do need to be able to download it. What's the secret? Do you have to condition the posting to allow downloading?
It's very common to point to the microphone and want a better one so everything will be OK. Probably not. Unless it's broken, the microphone is usually OK and it's the noisy room with echoes in it or bad microphone spacing or computer noise or other problem.
There is a sister posting to yours from an announcer whose only problem seems to be a noisy computer in the same room during the recording. The recorded work will not pass AudioBook noise tests. If they can't figure out a way to separate the performance from the computer, this could take a very long time. A new microphone is probably not going to help.
Post by kozikowski » Wed Jul 06, 2016 5:09 am
Do you know how to download the sound file from Clypt? I can capture it, but that's too complicated and doesn't preserve the voice volume.
Post by kozikowski » Wed Jul 06, 2016 5:10 am
Chains is Audacity version of Batch.
http://manual.audacityteam.org/man/chai ... ation.html
Post by kozikowski » Wed Jul 06, 2016 2:19 pm
He's almost right. His video is an instruction about how to make his voice sound better. He's recording with a very good quality microphone on a boom with rubbery vibration suppression spider and a pop and blast filter.
You can't see it in the introduction, but his room is more obvious in the segment where he shrinks his picture to the lower right.
Screen Shot 2016-07-06 at 6.46.12 AM.png (38.8 KiB) Viewed 1244 times
He's recording in a highly soundproofed studio with heavy drapes and what looks like expensive acoustic foam (the zig-zag pattern) on the walls. His room has no echoes and no noises. He said in the introduction that he is a published voice to large corporations, so no, he's not a home recordist.
So given all that, yes he can make his voice more crisp and broadcast bass rumbly with those two Effect > Equalization adjustments. The compression setting makes the voice more dense and forward, usually handy for commercials and promotional announcements (less handy in audiobooks).
If you don't start with a perfect studio voice, all those adjustments make the sound much worse.
The low (left-hand) equalization will make traffic noise, refrigerator and air conditioning rumble much worse. We usually recommend dropping those tones to get rid of rumble problems, not boosting them. The other two adjustments, high (right-hand equalization) boost and compression make room noises, neighborhood sounds and computer fan noises much worse.
If you make the show too crisp and harsh, ACX AudioBook may remove some of it before they publish your work. We had a recent poster where that happened. In some shows, they will reject the work as being "overprocessed."
His room has no echo. That's the sound of recording in a kitchen or bathroom. There is no correction for that. You get rid of that by reshooting in a better room.
So his video is more how to change your studio voice to match what your corporate client wants, not how to fix recording problems. I think it's just a promotional video to help sell his work.
weiss24
Post by weiss24 » Wed Jul 06, 2016 4:29 pm
kozikowski wrote:At first quick pass I don't hear anything wrong with it, but we do need to be able to download it. What's the secret? Do you have to condition the posting to allow downloading?
Seems like I had to. I've adjusted the settings, and the two clips are now downloadable.
kozikowski wrote:It's very common to point to the microphone and want a better one so everything will be OK. Probably not. Unless it's broken, the microphone is usually OK and it's the noisy room with echoes in it or bad microphone spacing or computer noise or other problem.
My desktop is noisy. Do you have a recommended method for reducing noise on the recording?
Post by kozikowski » Wed Jul 06, 2016 4:55 pm
I missed the step where I suggest corrections. I'll give that a shot when I get back to the shop.
Post by kozikowski » Wed Jul 06, 2016 7:03 pm
That's more better. Attached sound clip and AudioBook test. See sentence 2/3 of the way down.
Screen Shot 2016-07-06 at 11.34.28.png (36.81 KiB) Viewed 1233 times
That was not easy. That took multiple passes of noise reduction and I had to take out a house wall power hum tone that your microphone has. Then I had to suppress microphone hiss. Compare the two sound clips. See how the sound is clear, but gets really quiet when you stop talking.
Even with all that, it still sounds a little like you're talking in a room with bare floors and nothing on the walls. You are, right?
Since I know how to get it this far, I would recommend you work on theater. I know people who read with a similar odd vocal swing and pronunciation. That doesn't bother me. You have my problem. I tend to a monotone (puts people to sleep) rather than a broad range of interesting tones and even worse, it sounds funny when I try to force anything else.
But yes, the room is very noisy. During the reading I could hear you making click, thump and moving stuff around noises. You can help that with a towel or blanket over your desk while you record.
Are you recording in the same room with a noisy computer? That's a problem. Can you stop doing that?
I posted a discussion of things you can do to quiet a room.
http://forum.audacityteam.org/viewtopic ... 10#p308510
It turns out the poster had done a tent with blankets over it using plastic plumbing pipes jammed together and it worked just fine, but she still had some odd noise coming from somewhere and that's what we're looking for.
Any of those things is a terrific start. I don't want to post a long laundry list of corrections because most of the problems are easily fixed with simple soundproofing. All corrections harm the sound a little. The less work the better. When you get closer, I'll correct again and post what I did.
20160705CommagetsacureACX-Correction.wav
(1.71 MiB) Downloaded 41 times
