The subsonic.ny plugin will not enable (v 2.1.2)
Black Dog Bluez
Operating System: Windows 7
Post by Black Dog Bluez » Thu Jun 30, 2016 2:09 am
The subsonic.ny plugin will not enable in the effects manager (v2.1.2, 2016). Is it outdated or something? Thanks.
Re: The subsonic.ny plugin will not enable (v 2.1.2)
Post by Gale Andrews » Thu Jun 30, 2016 12:34 pm
If you have a problem with Audacity, it is best to post on the Windows board.
Make sure you have Audacity 2.1.2 supplied by us http://audacityteam.org/download/windows.
The only subsonic.ny file I can find is http://www.audacity-forum.de/download/e ... ubsonic.ny which is mentioned on http://wiki.audacityteam.org/wiki/Reducing_noise.
This plugin can be successfully enabled (I tried it on Windows 10) by following the instructions at http://manual.audacityteam.org/man/effe ... st_effects and http://manual.audacityteam.org/man/mana ... yzers.html.
If there are problems, exit Audacity and delete the file "Users\<your username>\AppData\Roaming\Audacity\pluginregistry.cfg" then try again.
Black Dog Bluez
Post by Black Dog Bluez » Fri Jul 01, 2016 11:10 pm
Thanks for that Gale, can you move this to the mentioned category? If so, do and I will try to be more specific.. next time..
I do have the latest Audacity 2.1.2
And yes, pretty sure that's where I got it, "audacityteam.org/wiki/Reducing_noise"
And I tried everything else you mentioned. I am familiar with adding plugins to Audacity, I have quite a few I've added.. and never had this problem.
The only thing I can think of is that my computer is Windows 7 rolled back to factory settings (with no additional Microsoft updates, but like I stated, have had no problems). I use this computer offline and do not have internet at home regardless, even if I did want to update it.. But it works fine as is and is probably less encumbered with updates this way anyway.
Also, the plugin, subsonic.ny, (copy I have) is 242 bytes in file size. I will download this plugin again to verify the size and retry as well.. Thanks.
Black Dog Bluez
Post by Black Dog Bluez » Fri Jul 01, 2016 11:20 pm
Okay, now the size is 740 bytes, will try asap.. Not sure what happened the first time ..it downloaded to a 242 byte file size.. Anyway will post results back asap. Thanks.
Post by Gale Andrews » Sat Jul 02, 2016 2:09 pm
Yes, subsonic.ny should be 740 bytes.
I moved the topic to the Windows board.
Black Dog Bluez
Post by Black Dog Bluez » Sun Jul 03, 2016 11:43 pm
Okay, I have a good download now and it enables as should, thanks..
Question 2.) What is it? How is it different than High Pass Filtering, all I found on it is this, at the same page it's available for download:
Subsonic Noise
While removing hi-band noise might be considered optional, removing subsonic noise seems mandatory to the writer. In contrast to hi-band noise you can apply subsonic reduction as a step in the mastering process, on the mixed and processed material, before a final Normalize.
Subsonic or low-band noise can enter your recorded material in many ways, such as through physical vibrations during the recording or noise from the tape machine (if you still use one of those).
Everything below 20 Hz is called "subsonic" because the human ear is unable to perceive it as recognisable sound. You can recognize subsonic noise by eye when the zoomed in waveform in Audacity is not symmetrical along the time axis. If you have already applied normalization in Audacity as recommended above, this should have removed any DC offset in the recording. The reasons for removing subsonics are the same as with DC offset - they will reduce the headroom available on the recording by taking up dynamic range, and can introduce clicks when editing.
To remove subsonics from your track you may filter it with:
## Audacity's built in Equalizer under the Effect menu
## Audacity's built-in High Pass Filter under the same menu - set the cutoff frequency to around 25 Hz. You can repeat this same effect a couple of times if a sharper cutoff slope is desired.
## This Nyquist plug-in subsonic.ny. Right-click or control-click over this link, and save it as "subsonic.ny". See how to install Nyquist plug-ins.
After removing subsonic noise you can generally re-normalize your track, and it will appear louder yet much more defined in the bass.
Just curious, if there's more info on it, or it is some how different than above quote, thanks.
Post by steve » Mon Jul 04, 2016 12:59 am
Black Dog Bluez wrote:Question 2.) What is it? How is it different than High Pass Filtering,
It's just a high pass filter like the High Pass filter that is included with Audacity.
