I can't listen to tracks while I record [SOLVED]
EndieTheEnderman
Post by EndieTheEnderman » Tue Jun 28, 2016 12:07 am
Audacity version 2.1.2
Windows 10
When I record something while I have a second track(that isn't on mute), I can't hear the track while I record, though I was previously able to.
This started happening after I plugged in a Blue Snowball mic, but I only plugged it in once, and then I stopped using it.
Re: I can't listen to tracks while I record
Post by steve » Tue Jun 28, 2016 12:16 am
Check that the playback device setting in the device toolbar is set to the device that you wish to play back through.
EndieTheEnderman
Post by EndieTheEnderman » Tue Jun 28, 2016 3:37 am
steve wrote:Check that the playback device setting in the device toolbar is set to the device that you wish to play back through.
I have it set on MME
By the way, I can listen to the music when I press play, but when I record it's silent.
(I forgot to mention that)
Post by Gale Andrews » Tue Jun 28, 2016 2:04 pm
MME is only the Audio Host. Steve meant the Playback Device (the last box on the right of Device Toolbar).
But from your description above, make sure Transport > Overdub has a tick (checkmark) by it. Click it if it doesn't.
Post by steve » Tue Jun 28, 2016 2:05 pm
EndieTheEnderman wrote:I have it set on MME
That's the "host sound system". The playback device setting is the last dropdown menu on the right end of the Device Toolbar. See: http://manual.audacityteam.org/man/device_toolbar.html
EndieTheEnderman wrote:By the way, I can listen to the music when I press play, but when I record it's silent.
:) That's important.
Look in the Transport menu, near the bottom. Ensure that "overdub" is selected (enabled) and "software playthrough" is not selected (disabled).
EndieTheEnderman
Re: I can't listen to tracks while I record [SOLVED]
Post by EndieTheEnderman » Tue Jun 28, 2016 11:00 pm
Thanks, it's working now. =)
Have a nice day! =D
