I use Audacity 2.1.0 on Windows 7 a lot; I'm careful with guidelines about moving and renaming file names and data folder names--which is why I'm so confused right now.
Last Friday, I worked for a couple of hours on a project involving multiple voice and music and sound effects tracks. I habitually hit ctrl-s while working, and when I finished for the night, I closed the project. There was no error, no indication that I hadn't saved or anything; I assume I saved it, because I always save things, and there was no error. I shut the laptop, without shutting down the computer. Then on Monday morning (today), I opened the laptop, opened the project in Audacity, and it gives me the error "Couldn't find the project data folder."
I checked the folder, and the program was right: the data folder wasn't there where I expected it to be. I searched the entire hard drive for the folder, in case it was moved somehow, but it doesn't seem to exist. It's not in the recycle bin, either. Seems to have disappeared.
Any ideas of what might have happened, or where it might be?
In case it helps, here's the top of the aup file when I open it in Notepad; after this is lots and lots and lots of data, which seems to prove that a data folder did once exist, I think?
Code: Select all
<?xml version="1.0" standalone="no" ?>
<!DOCTYPE project PUBLIC "-//audacityproject-1.3.0//DTD//EN" "http://audacity.sourceforge.net/xml/audacityproject-1.3.0.dtd" >
<project xmlns="http://audacity.sourceforge.net/xml/" projname="introwithscript-6-14-16-edited-firstgoataddingstuff_data" version="1.3.0" audacityversion="2.1.0" sel0="559.3371749815" sel1="579.3371749815" vpos="32" h="542.8300619855" zoom="37.8018857779" rate="44100.0" snapto="off" selectionformat="hh:mm:ss + milliseconds">
