Exporting WAV 8-bit (mono) saves at .AIFF?
Mopho007
Post by Mopho007 » Thu Jun 23, 2016 5:57 pm
Hey Guys,
I'm trying convert some 16-bit mono WAV files to 8-bit mono WAV. When I go to Export Audio I have to set the File Type to "Other uncompressed files" to get a 8-bit option. I set the header to WAV (microsoft) and Encoding to "Unsigned 8-bit PCM" but what it saves is a .AIFF file!?!?! I need WAV format.
Tried this same thing on my Mac (OSX 10.9) and it does the exact some thing, saves the file as .AIFF rather than a .WAV file???
Any help how to resolve this issue would be great. Thanks!
Mopho007
Re: Exporting WAV 8-bit (mono) saves at .AIFF?
Post by Mopho007 » Thu Jun 23, 2016 6:59 pm
UPDATE: Seems you need to add the .WAV extension to the name OR it defaults to a .AIFF extension.
Post by kozikowski » Thu Jun 23, 2016 8:20 pm
Yes. That is an actual bug.
Post by Gale Andrews » Fri Jun 24, 2016 12:45 pm
The bug is mentioned in the 2.1.2 Release Notes and has already been fixed in our source code so it will be fixed in the next 2.1.3 release of Audacity.
