What's the deal here?
Why is Audacity Importing MKV audio at 16bit?
TheLastOfUs
So I export a 32bit audio (MP3) and then save it to a mkv. When I drag the mkv into audacity - it picks this up as a 16-bit file......However if I use MKVExtract to EXTRACT the audio from the mkv and open in audacity - comes out at 32 bit.
Re: Why is Audacity Importing MKV audio at 16bit?
Internally, Audacity always works with 32 bit floating numbers for precision. If you import a 16 bit audio file, it will be converted to 32 bit float. Even 8 bit audio will be converted to 32 bit on import.
When exporting, you can choose the bit depth. 16 bit is sufficient, unless you want to work with the audio in another DAW. In that case, choose 24 bit.
An MP3 is always 16 bit max. MP3 is a compressed, lossy format, so some samples might be a lot less than 16 bit. You can't choose the bit depth. The compressor chooses that for you, according to the content of the sample.
WAV is an uncompressed format. It can be 16, 24 or 32 bit. 32 bit is rarely used as an export format, as it creates huge files and is only needed when going from one DAW to another, fi for mastering.
FLAC is a compressed, lossless format and will take any bit depth and resolution you throw at it. There are others, like Wavpack.
- Quality Assurance
The import behaviour depends on the importer. You are using FFmpeg to import MKV, and for MP3 content, that means the MP3 audio in the MKV will import as 16-bit resolution PCM audio.
MP3's are a 32-bit float stream as I understand it. The author of the libmad MPEG decoder library told me so. Regardless, most applications will just report MP3's as "16-bit". What bit depth they are decoded at depends on the application playing it. Libmad provides 24-bit PCM output.
While that is technically true, Gale, it has nothing to do with the audio. It's the stream that is transported in 32 bit morsels.
That's why most programs will report it as 16 bit, although it is really 15 bits. The 32 bits in an MP3, are data bits, not audio samples. MP3 uses Huffman symbols to store audio. As such, there is no "bit depth" in an MP3. The frames an MP3 is holding, can not be individually decoded, as some information may reside in previous frames.
Unfortunately, the only site I know that has some docs about it, xingtech.com, seems down for me at the moment. Unless you want to go to Fraunhofer, and pay $$$ to read the original specs. There's some good info here, though:
http://blog.bjrn.se/2008/10/lets-build-mp3-decoder.html
That kind of confusion is also why I don't applaud it when Audacity imports a 16 bit audio file and shows 32 bit in the left window pane. In my mind, it should report the original bit depth, as the conversion only adds zeroes. Too many people look at the numbers without understanding and suppose there's some magic that adds resolution.
Robert J. H.
The bit -depth code I've provided at another place does usually report 29 bit for an imported Mp3 file. This corresponds to a bit depth of 14.5 bit which is in accordance with the specs.cyrano wrote:While that is technically true, Gale, it has nothing to do with the audio. It's the stream that is transported in 32 bit morsels.
Btw, single frames can be read if the bit reservoir had been set to false during encoding.
Robert
thx, Robert. Good to know.
I tend not to confuse people by talking about half bits. It's something that's way over my head too
Robert J. H.
I feel with you.cyrano wrote:thx, Robert. Good to know.
The most efficient compression algorithms work with fractal bits, such as
https://en.wikipedia.org/wiki/Arithmetic_coding
However, the reason for the Mp3 oddity is based on the spectral representation/quantization, rather than the coding itself.
Robert
- Quality Assurance
I am not totally clear about "corresponds to", Robert. Is that about the capability of the decoder, which would often be 16-bit?Robert J. H. wrote:The bit -depth code I've provided at another place does usually report 29 bit for an imported Mp3 file. This corresponds to a bit depth of 14.5 bit which is in accordance with the specs.
It seems ambiguous to me to call MP3's 16-bit. Given the "bit depth" of the audio samples isn't constant, how would you describe their "bit depth", and is it float or integer? What provides the ability of MP3 to store audio above 0 dB?
Robert J. H.
The samples are stored as quantized frequency bins after going through a modified Discreet Cosine Transform. The whole compression takes place in this domain.Gale Andrews wrote:I am not totally clear about "corresponds to", Robert. Is that about the capability of the decoder, which would often be 16-bit?Robert J. H. wrote:The bit -depth code I've provided at another place does usually report 29 bit for an imported Mp3 file. This corresponds to a bit depth of 14.5 bit which is in accordance with the specs.
There, we don't have the +/-1 restriction as in the time domain. the peak can therefore go over 0 dB once the samples are transformed back.
It is nigh impossible to relate the different transforms in a 1:1 manner to the impact on bit depth. I can only provide the empirical observation that the audio has 29 bit after decoding. Or in other words, 3 bits of the possible 32-bit float number aren't used. I have no idea what happens in the final decoding state, whether zero padding is applied or whatever. There are cleverer guys than me out there that can do the reverse engineering if they want to.
I'm waiting for a lossless 32-bit float compression format. That would be beneficial for Audacity as well.
TheLastOfUs
So from this discussion I got MP3s are lossy...always 16 bit maximum bit depth anyways..but my whole point is - when importing a .mp3 outside of a .mkv it imports at 32 but not when dragging the MP3 actually into audacity from the .mkv itself using ffmpeg.
Why is it this way? You guys are kind of telling me what I already knew from the OP (that it imports at 32 bit) which it's not doing unless the .mp3 is extracted. In any case I don't think it would be wise to change the bit depth of the .MP3 from a .mkv import to 32 bit...don't think that makes sense if the Importer for MKVs is screwy and importing only at 16 bit.
