Remove "metallic" sound from clip?
busterbie
Post by busterbie » Thu Jun 16, 2016 5:01 pm
https://youtu.be/81cSEgfngZ8
So i am currently trying to make a "fire burst" sound effect for a game, i recorded a t-shirt wich i shaked/vibrated with a big burst in the air near the microphone (wich may i add is an ipads microphone so very low quality here)
Now on low volume the sound is, okay, but turning it higher up gives this weird "metalic" sound. Any reccomendations for how i could remove that?
Re: Remove "metallic" sound from clip?
Post by kozikowski » Fri Jun 17, 2016 3:57 am
I think you're stuck. You're in a teeensy subset of users, producers who make their own game sounds, and I don't think there are any forum elves who regularly do that. So that leaves you with somebody who does what you do who happens to drop in from userland and not only doesn't have their own problems, but has time to work on yours.
Trebor
Post by Trebor » Fri Jun 17, 2016 6:25 am
busterbie wrote:So i am currently trying to make a "fire burst" sound effect for a game ... but turning it higher up gives this weird "metalic" sound. Any reccomendations for how i could remove that?
Spectral edit tool can be used to remove unwanted bits ...
before-after.flac
(568.12 KiB) Downloaded 26 times
before-after[+flanger].flac
(338.5 KiB) Downloaded 18 times
http://wiki.audacityteam.org/wiki/Nyqui ... 8linear.29
Freesound has more gunfire samples than you can shake a stick at ...http://www.freesound.org/search/?q=gun+fire
