mic input level not staying 'put'
I need to set the mic input level to 7 to have a quiet noisefloor for recording. But, it inevitably inches its way up to 10. How can I keep this set?
Re: mic input level not staying 'put'
My first guess - shut down Skype.
If that's not it, please tell us more about your set-up.
Which version of Windows?
Which exact version of Audacity (look in "Help > About Audacity")
What are you recording?
What hardware are you using? (model numbers are good)
Has it ever worked?
Anything else that you think could be relevant?
Has it ever worked?
I rebooted and the problem is fixed for now!?! I will let you know if it happens again. Thanks!
