setting for recording from sound card only when playing
movebetter
Operating System: Windows 7
Post by movebetter » Tue Jun 07, 2016 8:54 am
Audacity 2.1.1 window 7 pro
any setting for recording from sound card only when sound is being played? i want to record several tracks while away from computer. thanks
i was given this solution which i thought was the answer (Edit -> Preferences -> Recording -> Sound Activated Recording) but when i tried it, it didnt work. still keeps recording nothing.
Re: setting for recording from sound card only when playing
Post by steve » Tue Jun 07, 2016 11:08 am
Sound Activated Recording will record whenever the input signal is greater than the "activation level". If the background noise is greater than the activation level, then the recording will be continuous, in which case you need to raise the activation level so that recording is not activated by the background noise. See: http://manual.audacityteam.org/man/tran ... u.html#sar
