Audacity 2.1.1 window 7 pro
any setting for recording from sound card only when sound is being played? i want to record several tracks while away from computer. thanks
recording only when sound is played [SOLVED]
movebetter
- Operating System: Windows 7
Re: any setting for recording from sound card only when soun
Edit -> Preferences -> Recording -> Sound Activated Recording
movebetter
