Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Stephan1953
Post
by Stephan1953 » Fri May 27, 2016 12:25 am
Hello,
I am using windows vista Basic and Audacity 2.0.6.0
I recently imported a Stereo MP3 and when I tried to fix the Audio, I noticed the Left channel was half as loud than the Right .....
Is there a way to fix only the left channel without touching the Right Channel
PS I Also have Audacity 2.0.6.0 Installed on my Desktop that has Windows 10,
Thanks
Stephan
DVDdoug
- Forum Crew
Post
by DVDdoug » Fri May 27, 2016 2:07 am
Does it sound out-of-balance? Usually the channels will look similar but don't just go by how the waveform looks. The peaks don't correlate perfectly with perceived loudness.
OK...
- There is a little drop-down arrow to the left of the waveforms. Click that and then click "Split Stereo Track". That will allow you to edit the left & right channels separately.
- Click & drag to select the entire waveform that you want to change. Use the Amplify effect to boost the volume.
themickster
Post
by themickster » Fri May 27, 2016 8:39 pm
Try Audacity 2.1.x.
Stephan1953
Post
by Stephan1953 » Thu Jun 02, 2016 12:35 am
Thank-you Doug...And yes the Volume peaks are way out of sync....you can see the louder Right Channel and the very Low Left channel... and thanks I will try the your suggestion........Stephan
