07:38:16: Error: Failed to load shared library ‘C:\Program Files\Audacity\plug-ins\hard_limiter_1413.dll’ (error 126: no se puede encontrar el módulo especificado.)
Do you mean the LADSPA “Hard Limiter” plug-in?
Which version of Audacity are you using? (look in “Help > About Audacity”)
Which version of Windows?
If you are using a recent version of Audacity, there is a new Limiter effect included that generally gives better results than the old LADSPA effect: http://manual.audacityteam.org/man/limiter.html
