Just found one old Audacity file in Programmes & Features that I didn't know was still there as I thought I'd erased all the old remaining ones. Removed it and it then downloaded with no problem at all !
Hopefully I'll be able to get it all up and running for Dragon 13 tomorrow and why I had to buy a Pro-Sound mike in Maplins as they discovered the original Lenovo one in the laptop wasn't good enough. All new territory however....
Unable to start Audacity after download ?
