Strange: Applying effect removes waveform
themickster
Re: Strange: Applying effect removes waveform
My advice was for trying to stop the problem, not trying to access the logs. I didn't think reverb was a Nyquist, either.
- Quality Assurance
It's a perfectly reasonable suggestion, but all I was trying to say was that if the machine was very short of RAM then doing something like opening another window in Audacity probably wouldn't even display the window properly.themickster wrote:My advice was for trying to stop the problem, not trying to access the logs.
themickster
It would only mean opening a different one, not an extra. I did it when I had the same problem and fixed it.
themickster
My first move would be installing Audacity on the daughter machine and seeing if that solves the problem.
