I have a directory with 87 wav files, consisting of 4 octaves of C notes played on synths, normally 2 synths per file. So 8 per file, making around 696 samples.
Will you be splitting into 8 equal length sections, or do you need the batch process to somehow “detect” where to split? If the latter, then how will the process work out where to split?
How long is each file?
So do some files have more / less than 8 sections?
The missing piece in the jigsaw is that Chains do not support Export Multiple. Do you want to “vote” for that? Sometime we will improve Chains by adding missing features so we will review requests when we do that.
