Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
yugioh47
Post
by yugioh47 » Sat Mar 12, 2016 2:48 pm
Gale Andrews wrote:
But you can fix that, as I said. Delete the existing command for the effect in Edit Chains. Click "Insert" then add the effect from the list. Click "Edit Parameters" to choose the parameters you want.
I've trid that out and the chain isn't allowing me to do the commands by editing the command for the effect. there some kind of issue with the chain. just don't kown what it is.
yugioh47 wrote:which compiler should i use that is freeware for xml files to *.dll?
Gale: What are you trying to do?
i'm trying to compile LADSPA plugins that are up to date. which program do you recommend for doing this?
- Quality Assurance
Post
by Gale Andrews » Sun Mar 13, 2016 4:52 pm
We don't know either unless you give much more detail about the error, or perhaps attach the Chain so we can see it.
It may be simplest to create a completely new Chain using the "Add" button.
yugioh47 wrote:i'm trying to compile LADSPA plugins that are up to date. which program do you recommend for doing this?
Why do you need to update the plugins? They are not that different.
I think you would either use
minGW or install Microsoft Visual Studio and look in the folder "win\LADSPA_plugins-win" in the Audacity source code. But those Audacity instructions are years outdated and won't work "as is".
yugioh47
Post
by yugioh47 » Sun Mar 13, 2016 7:09 pm
the chain doesn't allow me to edit the commeands the window comes up for the error not to edit the commeands
like it say's. i'll do a short video on this to show what the error is. i don't do effects on the video. i like it raw just to show you what error i come up with.
minGW or install Microsoft Visual Studio and look in the folder "win\LADSPA_plugins-win" in the Audacity source code. But those Audacity instructions are years outdated and won't work "as is"."
thanks. i need them for fixed bugs if any.
Gale Andrews on Mon Mar 14, 2016 2:25 pm, edited 1 time in total.
Reason: Fixed quote tags
- Quality Assurance
Post
by Gale Andrews » Mon Mar 14, 2016 3:21 pm
As I said, use the
Add button to left of Edit Chains.
If you are still stuck, please create a ZIP file containing the plugin you are using and the Chain file you are using. To find the Chain file, paste:
into the Explorer address bar and press ENTER on your keyboard.
Also tell us exactly what values you want for each parameter in the effect.
I cannot test this because I cannot find the plugin you are using. Is it
http://plugin.org.uk/ladspa-swh/docs/la ... tml#id1189? That plugin isn't actually included in the LADPSA-swh plugins installer we offer.
yugioh47
Post
by yugioh47 » Mon Mar 14, 2016 6:37 pm
- Quality Assurance
Post
by Gale Andrews » Tue Mar 15, 2016 2:32 pm
We can't help you unless you do exactly as I requested in my previous post. As I explained, I don't have and cannot find anywhere to download that plugin.
yugioh47
Post
by yugioh47 » Tue Mar 15, 2016 11:09 pm
well i found with ladsapa plugins.
here's the file:
https://www.dropbox.com/s/j6zgyt5ymlw5m ... 8.zip?dl=0
yugioh47
Post
by yugioh47 » Wed Mar 16, 2016 8:42 pm
ok here are the settings for the error message that it shows in the box:
Frequency_(Hz)="440.000000000000" Modulation_depth_(0=none,_1=AM,_2=RM)="0.000000000000" Sawtooth_level="0.000000000000" Sine_level="1.000000000000" Square_level="0.000000000000" Triangle_level="0.000000000000"
- Quality Assurance
Post
by Gale Andrews » Thu Mar 17, 2016 6:09 pm
I did not realize that ringmod_1188.dll also loads ringmod_with_LFO_1199.
I don't know if that linkage is the cause of the problem but I am afraid the upshot is that you can only use either of the effects at default settings in a Chain. I can find no workaround by editing the Chain file or using a saved preset in the Chain.
Also if you use either effect from the Effect Menu they don't remember their settings when you open them in the next Audacity session. The settings are written to pluginsettings.cfg but Audacity does not load the settings.
I will add a bug report when I have time.
