2.1.2 (from .exe) Windows 7; monitor active; does not record
Re: 2.1.2 (from .exe) Windows 7; monitor active; does not re
Post by Gale Andrews » Tue Feb 16, 2016 1:50 pm
OK then we are sure now you have the correct audio drivers for the built-in sound device.
Your Audacity audio device info does not show line in, only microphone and Stereo Mix.
I think the only way you might be able to improve things is to go into Windows Sound. Change to the "Recording" tab. Right-click anywhere inside the Recording tab and if available, choose "Show disabled devices" then right-click again and check "Show Disconnected Devices".
What devices do you see now. Mic, Line-in and Stereo Mix?
As I said before, to record from Stereo Mix, you will need to set the Line-In to "Listen to this device", so that it plays through the computer speakers. To do that you would right-click the Line-In, choose Properties, then click the "Listen" tab. Then restart Audacity and record from Stereo Mix.
Are you connecting the turntable directly to the computer input? If you want to record a conventional turntable it is better and simpler to attach its output to a phono amplifier then connect the amplifier to the computer. This gives you proper RIAA equalization at already amplified line level.
Does your cassette deck with USB output have a line input? If so, you could connect the turntable through a phono amplifier to the line input of the cassette deck and record from the cassette deck. Otherwise I think you may be better buying something like the Behringer UFO 202: http://wiki.audacityteam.org/wiki/Recom ... Interfaces.
vjaroslaw
Operating System: Windows 7
Post by vjaroslaw » Fri Feb 26, 2016 6:51 pm
Thank you all:
I have been taking your advice and working things out. I super appreciate your time. P.S. Where can I make a small contribution to Audacity?
VJ
Post by Gale Andrews » Sat Feb 27, 2016 1:28 pm
vjaroslaw wrote:I have been taking your advice and working things out.
Let us know some details of how you fixed it, or if you need more help. Other people reading this might benefit from that.
vjaroslaw wrote:Where can I make a small contribution to Audacity?
We would appreciate a small donation if you can. Please see http://old.audacityteam.org/donate/.
Thanks.
