Hi all,
Newb here....running Windows 7....uninstall 2.1.1 before updating, or will 2.1.2 smoothly overwrite 2.1.1?
Thanks in advance
bkburkhead
newb question - updating to 2.1.2
bkburkhead
- Operating System: Windows 7
Re: newb question - updating to 2.1.2
If you want it to retain all your preferences and settings, just install it.
If you want to burn it off, hose it down and start over, say so. The installer will ask you if you want to keep your preferences. Say no.
bkburkhead
Koz,
Thanks.
bkburkhead
Thanks.
bkburkhead
- Quality Assurance
There is a FAQ Windows: How do I install Audacity, and do I have to uninstall a previous version first? that answers these questions.
