Sound Activated Recording 2.1.2 not working properly
waxcylinder
Re: Sound Activated Recording 2.1.2 not working properly
Post by waxcylinder » Thu Feb 04, 2016 4:42 pm
themickster wrote:Connaway, you're not the only one that's given up on 2.1.2. There's been a code change somewhere making plugins and other stuff not work.
Well that's not my experience. I was heavily involved in the alpha testing stages of 2.1.2 and it never really faltered for me - to the extent that I took the risk of using those later alphas for my production work. I have no problems with plug-ins not working either.
dendryite
Post by dendryite » Mon Jul 16, 2018 7:28 pm
I am having the exact same problem as Connaway.
I do appreciate this excellent program, so I hate to complain ;o)
Post by steve » Mon Jul 16, 2018 8:41 pm
The first thing you should do is upgrade to Audacity 2.2.2, which you can get via the Audacity website: https://www.audacityteam.org/download/windows/
DVDdoug
Forum Crew
Post by DVDdoug » Mon Jul 16, 2018 9:32 pm
Are you also recording from a USB headset?
What have you selected as your Recording Device?
In general... If you set the threshold too high (a small negative dB number) recording may not start.
If you set the threshold too low (a bigger negative dB number) recording may be triggered continuously by background noise (acoustic or electronic noise) and the recording may never stop/pause.
If you can't find a setting that works (no false-triggers and no misses) then sound activated recording may not be appropriate for your application.
