Noise Elimination
kurier44
Noise Elimination
Post by kurier44 » Mon Jan 18, 2016 7:41 pm
Windows 7....I have recorded audio from a cassette and I am experiencing difficulty in eliminating a "thumping" or "popping" sound. I just made an attempt to forward a WAV file of the recorded audio a an attachment, but for some reason it did not work. Any feedback will be appreciated!!
Re: Noise Elimination
Post by kozikowski » Mon Jan 18, 2016 9:43 pm
A forum posting will only support about five seconds of stereo and ten of mono. You can't upload a whole album or cassette.
http://forum.audacityteam.org/viewtopic ... 49&t=72887
Constantly changing foreign sounds can be very serious. There are very few tools or filters available for that kind of damage.
Make sure you have a safety backup of all your work (thumb drive in your pocket?), reduce the work to mono with Tracks > Stereo Tracks to Mono, drag-select ten or twelve seconds of distortion, post as WAV (Microsoft) and post it.
Start to think about what would happen if we can't clean the damage.
