Recording flash cards, trimming end of audio file possible?
weiss24
Post by weiss24 » Sat Jan 16, 2016 2:24 am
Hello!
I click on play with my recorded flash cards, and then let Audacity record all the 100+ cards into one large mp3 file. But is there a way of either getting it to stop recording when the sounds have ended, or trim the silence at the end?
If I leave the PC while it records, there will inevitably be a very long silence at the end ...
Re: Recording flash cards, trimming end of audio file possib
Post by Gale Andrews » Sat Jan 16, 2016 11:51 am
Was this about using Audacity for an educational purpose? Assuming not, it is best to post in the Forum board for your operating system, so I moved the topic for you.
Try Transport > Sound Activated Recording (on/off).
If you need more help, please tell us your version of Audacity (see the pink panel at the top of the page).
weiss24
Post by weiss24 » Sat Jan 16, 2016 1:10 pm
Depends on how one would define educational purposes. I will record the names of all capitals and countries with associations, and then listen to them to learn it one and for all.
I guess the question is mostly support related. I will try Transport. I am using Audacity 2.1.1
