I had not intentionally been in Record mode, but my recollection is unreliable. It happened Monday and I appended it from my notes while reporting the 2.1.2 event.Gale Andrews wrote:The "B" and "C" bug ceases in 2.1.1 once you record.
Source of the audio was an existing project on which I had been doing various parts of the editing using different Audacity versions for test purposes. Recalling the size of the approx. 3 second selection on screen, I was zoomed in 1 click. 01:55:22+45f was the length after the deletion - I selected the whole track to get this for documenting the event, which was after deleting. Sorry about the ambiguity there. Also, Snap was OFF. I've never attempted to learn whether that matters (note to self...). Sync-Lock was ON, but I have found that to not matter.Gale Andrews wrote:So you were already zoomed in but no-one knows how far, we don't know the source of the audio (file or recording), also it is not clear whether the duration was 01:55:22+45 CDDA frames before or after the deletion.
I'll go back to RC2 when I'm not splitting a track, since that one did it much more often. I went to this build because I expected to be splitting off mono portions for exports, but didn't get that far. This is the first time I've seen it happen in this build - I thought it was fixed, either collaterally or methodically.Gale Andrews wrote:I am still not able to reproduce any failure, using your information above. Thanks for pursuing this, but it's unlikely to be fixed unless you can post a project that can reproduce it at least some of the time.
The fact that in this nightly build (1/9/2016) starting play with the space bar doesn't fix the condition whereas in RC1 and RC2 it does might be the most pertinent clue added by this experience. Sorry I neglected to try the Transport Start button, which fixes it in RC1 & RC2.
