I don't think so, but I can add it sometime if not.waxcylinder wrote:Is there a Bugzilla enhancement request for this?
But first we would have to be clear what we want. Separate preferences for export directory and save directory? Or specify the starting directory internally, and if changed by the user, just write that to audacity.cfg (as happens already for the export path)?
Note that http://bugzilla.audacityteam.org/show_bug.cgi?id=550 suggests we have three choices for export path: Path of original file/last used/user-specified. The point of "Path of original file" is to make it less onerous to import a file for overwrite, so that it is never necessary to change the export directory.
Of course if we ever had a properly thought out File > Overwrite menu item, bug 550 would close, then the case for a Preference or not would rest on the issue being discussed here.
