Administrator approval
oldnfrailer
Re: Administrator approval
Post by oldnfrailer » Sat Jan 09, 2016 12:10 am
Robert2 wrote:On recent Windows systems, you cannot automatically save files to your system drive, except to the approved folders like “Documents”, “Videos”, etc..
You might be able to save files to non-approved folders, but this will have to be done manually, and you will have to give special Administrator’s authorizations.
Thanks for the reply. Where do I get/give Administrators authorizations?
oldnfrailer
Post by oldnfrailer » Sat Jan 09, 2016 12:14 am
steve wrote:For some reason (I don't know why), when you first use Audacity the default export directory is the directory where Audacity is installed (usually inside the "Programs" directory). "User files" (your files) should NOT be saved there. You should always save your documents, pictures, music, and other "user files" within your "user space", such as in the "Documents", "Music" or "Videos" folders. Standard user accounts are not allowed to save documents in system / program folders, and that is why you are prompted for an Administrator password.
When you Save or Export from Audacity, ensure that you are exporting / saving to a location where you are allowed to save files with your normal user account.
Thank you for the reply. Have been saving "trials/tests" to documents.
oldnfrailer
Post by oldnfrailer » Sat Jan 09, 2016 12:17 am
Robert2 wrote:In recent Windows systems, programs are not allowed to automatically save documents to system / program folders even if you are logged into Windows as “Administrator”. In recent Windows systems, especially in Windows 10, all user accounts are treated as “ordinary” accounts, even the super “Administrator” account. In Windows 10, even “Administrators” cannot do as they please unless they show appropriate credentials.
Thanks for your reply. Guess I'll have to research Win 10 "Administrator".
oldnfrailer
Post by oldnfrailer » Sat Jan 09, 2016 12:20 am
kozikowski wrote:Best pure computer joke of 2015:
"Behave yourself, or we'll put Windows 10 on your computer."
Yeah... I have a "Grumpy Santa image" I'll post for my friends: "Tired of Nice. Next year its Naughty Toys for Naughty Girls and Boys' Date this. My thought first ;)
oldnfrailer
Post by oldnfrailer » Sat Jan 09, 2016 12:25 am
Thank all of you for your info.
Post by Gale Andrews » Sat Jan 09, 2016 12:14 pm
Make sure you are saving to your Documents and not someone else's.
If you don't get a prompt that requests the administrator password, then you may have permissions problems on the folder or it may be read-only. Right-click the folder, choose "Properties" then look on the "General" and "Security" tabs. You may need to log in as Administrator to change permissions or ownership on the folder.
oldnfrailer
Re: Administrator approval/Pause & save
Post by oldnfrailer » Tue Jan 12, 2016 2:30 pm
So, Win 10/Administrator Approval: Pinned Audacity app to start [TILE] To open, Rt click>choose run as administrator. One problem solved I think.
Pause /Save problem: Per manual: Before recording, from File choose 'save as...' and name the file etc. Now I can 'pause and save [close].
Thanks to all for help.
oldnfrailer
Post by oldnfrailer » Tue Jan 12, 2016 3:56 pm
See my entry of 1/12/16 Administrator/Pause/save.
Robert2
Post by Robert2 » Tue Jan 12, 2016 6:52 pm
Audacity should not have to be run as administrator with full unrestricted elevated rights. Audacity works perfectly well as a standard application with standard rights in Windows 10.
For a lot of users, running a standard application As Administrator often spells unforeseen trouble.
You might want to take a look at How to Run an App as Administrator in Windows 10
Here is from that page:
By default, any time you run anything as administrator (elevated), you will get a UAC prompt for approval first. This will not bypass it.
Post by Gale Andrews » Tue Jan 12, 2016 8:22 pm
oldnfrailer wrote:See my entry of 1/12/16 Administrator/Pause/save.
See http://forum.audacityteam.org/viewtopic ... 86#p295386. The only way you can Pause then Save is to choose File > Exit when paused (or use the red window Close button. And after save, Audacity then quits. This has nothing to do with the user rights you have.
