I did update my audacity to the latest version recently. Now I've noticed that "hard limiter" has gone.
There is a filter named "limiter" instead. I don't get how it works.
My workflow to audio tracks from videos that I made by myself (these are homemade videos, mostly more lo-fi from smartphones etc.):
1. High and Lowpass to remove fuzzy frequency garbage at the ends of the spectrum.
2. Copy the track.
3. low-passing the one track using a falling line in the equalizer
4. high-passing the other one using the opposite equalizer settings so both tracks being played togheter have the original sound again
5. set the low-passed one to mono
6. cut off the stronger peaks from both tracks using the hard limiter
7. apply "leveler" to the high-passed track
8. mixing the two tracks togheter. And low-passing the mix track again with same settings.
9. set to -6db (this is my standard gain for my homemade video files^^), compress and mux back to the video
This was an every-time-working workflow to kill harsh peaks. This also gave a nice analogue-like old movie sound. Almost every time a quick but good enough result to me.
Now I stuck at step 6 with the new limiter. I tried several settings but it seems to act more like a fast compressor or like recorded at too strong level that a limiter. The sound is pumpy, distorted and more like the results of an record produced for radio stations.
How do I get the old functionality with this new limiter (just rounding the peaks above the threshold without general changes to the dynamics). The upper handle was for threshold and the middle one for soft/hard. I never used the third one and left it to default (i never got what this one does
I don't want to use compressors at all here. In best case, these just make a record sounding flat and boring at all.
