Play Cut Preview (what am I missing?)
edwinn
Operating System: Windows 7
Post by edwinn » Wed Dec 16, 2015 12:47 pm
Hi,
When editing audios or lectures, many times its desirable to CUT short segments, like when the speaker coughs or stutters. I see in the HELP section a Play Cut Preview with shortcut C. This would be GREAT and would eliminate trial-and-error selecting, Z (zero-crossing), cutting and test playing.
Though the Shortcut C does nothing, no preview, etc. It could be too early in the morning, so please excuse being dense.
-Ed
Re: Play Cut Preview (what am I missing?)
Post by steve » Wed Dec 16, 2015 1:26 pm
Please state which version of Windows you are using, and the exact three-section version of Audacity (look in "Help > About Audacity")
Post by Gale Andrews » Wed Dec 16, 2015 1:37 pm
If you are using the current 2.1.1, the special playback commands do not work, due to a bug.
As a workaround, each time you open a new project window, press Record then Stop. You can close the recorded track afterwards.
edwinn
Post by edwinn » Wed Dec 16, 2015 1:59 pm
steve wrote:Please state which version of Windows you are using, and the exact three-section version of Audacity..
It's Audacity 2.1.1 running on Win-7, 64 bit.
-Ed
edwinn
Post by edwinn » Wed Dec 16, 2015 2:00 pm
Gale Andrews wrote:If you are using the current 2.1.1, the special playback commands do not work, due to a bug. As a workaround, each time you open a new project window, press Record then Stop. You can close the recorded track afterwards.
Ok THANKS.. I can deal with that. :D
-Ed
