ReaPlugs VST bug in 2.1.2
themickster
Post by themickster » Tue Dec 15, 2015 12:34 am
I installed the pre-release 2.1.2 and found a bug. ReaEQ either freezes or crashes when I try to do almost anything in it. I can load a saved setting,but I get a pop-up telling me that I'm loading a setting from a plugin into a standalone. It crashes as soon as I try to apply and no change happens to the track. I have not changed ReaEQ.
ReaEQ crash.zip
(140.21 KiB) Downloaded 49 times
Reason: Given more relevant title
Re: ReaPlugs VST bug in 2.1.2
Post by Gale Andrews » Tue Dec 15, 2015 1:20 pm
themickster
Post by themickster » Tue Dec 15, 2015 2:41 pm
Thank you.
Post by Gale Andrews » Sun May 22, 2016 5:42 pm
Gale Andrews wrote:Thanks. Added at http://bugzilla.audacityteam.org/show_bug.cgi?id=1279.
A possible fix has been committed now. Testing welcomed. The fix will be available in any Windows Nightly Builds on or after 23 May 2016.
themickster
Post by themickster » Sun May 22, 2016 9:08 pm
Thank you again.
themickster
Post by themickster » Mon May 30, 2016 5:28 pm
Fixed. Thank you.
