Dell Laptop 3520
lwelch39
Dell Laptop 3520
Post by lwelch39 » Tue Dec 01, 2015 11:49 pm
Dell has got a weird sound set-up for sure... Audacity worked great for a few days, then with headphones unplugged a time or two, audacity will no longer work no matter what setting I use. It will record from the internal mike, but that picks up background noise, basically is worthless. Anybody have any ideas? Laptop is setup onWindows 10.
Re: Dell Laptop 3520
Post by kozikowski » Wed Dec 02, 2015 12:19 am
To unscramble that:
You are trying to record from the microphone on your headset. You unplugged the headset and now the only microphone that works is the laptop built-in one.
Audacity checks for new devices when it starts. If you connect something after Audacity is already running, it will be invisible. Restart Audacity, or you can also Transport > Rescan. After you restart, you may need to tell Audacity what to record from with the device toolbar.
http://manual.audacityteam.org/o/man/de ... olbar.html
Is your headset visible and can you switch to it?
lwelch39
Post by lwelch39 » Wed Dec 02, 2015 12:25 am
Little slow here... record from 'Headset"? - Seems like it would work best to record directly from the sound card or something... My headset does not have a mic - weird thing about Dell is - you have to open panel and tell it to play internal speakers or HS - all other laptops I've had would switch when you plugged-unplugged.
Post by kozikowski » Wed Dec 02, 2015 12:27 am
OK, then I missed it completely.
What are you recording?
lwelch39
Post by lwelch39 » Wed Dec 02, 2015 12:28 am
Recording from Pandora - dont tell anybody tho....
Post by kozikowski » Wed Dec 02, 2015 1:13 am
You're recording audio playing on the computer.
http://manual.audacityteam.org/o/man/tu ... puter.html
cyrano
Post by cyrano » Wed Dec 02, 2015 8:05 am
lwelch39 wrote:Little slow here... record from 'Headset"? - Seems like it would work best to record directly from the sound card or something... My headset does not have a mic - weird thing about Dell is - you have to open panel and tell it to play internal speakers or HS - all other laptops I've had would switch when you plugged-unplugged.
To paraphrase Frank Zappa "Cheapness at work". They must have left out the "headphone plugged in" detection. Every cent counts when you're in the budget market...
Post by steve » Wed Dec 02, 2015 12:52 pm
kozikowski wrote:You're recording audio playing on the computer.
Which links to this page for Windows: http://manual.audacityteam.org/o/man/tu ... ndows.html
where you need to look at the "WASAPI loopback" method.
