Plugin crashes
themickster
Plugin crashes
Post by themickster » Sun Nov 29, 2015 7:52 pm
The software Marshall I use crashes. Logs attached.
XP
Audacity 2.1.1
jcm crash.zip
(131.18 KiB) Downloaded 16 times
Re: Plugin crashes
Post by Gale Andrews » Mon Nov 30, 2015 10:01 am
themickster wrote:The software Marshall I use crashes. Logs attached.
XP
Audacity 2.1.1
Thanks but please be more specific what software you are talking about, and what exactly you do (1, 2, 3...) leading up to the crash. Did you mean "Marvel" (Marvel GEQ.dll)? That is not implicated in the call stack, but Floorfish is the last plugin mentioned before the crash.
themickster
Re: Plugin crashes
Post by themickster » Mon Nov 30, 2015 8:15 pm
It's the Marshall JCM900 software amp at http://www.simulanalog.org/guitarsuite.htm
1. Select track
2. Open JCM900
3. Apply
4. Watch the crash
The crash does not happen right away if Audacity has only a short history. In that case, the crash and log warning happen in shutting Audacity.
That also happens when the plugin is the first step after opening Audacity and importing one wav into an empty file.
I still use the plugin because it's so good sounding.
New log attached.
jcmcrash.zip
(127.2 KiB) Downloaded 19 times
Re: Plugin crashes
Post by Gale Andrews » Tue Dec 01, 2015 12:43 pm
Thanks, I added a bug report http://bugzilla.audacityteam.org/show_bug.cgi?id=1270.
In my testing, if you use the Manage button in any of the effects, then Options... and set Buffer Size to "8", this may allow you to use the effect by just applying it, as long as you don't play audio while the effect is open.
The effects do seem to work without crash in Audacity 2.0.0, but not 2.0.6.
themickster
Re: Plugin crashes
Post by themickster » Tue Dec 01, 2015 2:59 pm
I'll try that. You gave me another idea too: make a chain with only that plugin in it.
Thank you
themickster
Re: Plugin crashes
Post by themickster » Wed Dec 02, 2015 2:55 pm
Setting buffer to 8 worsened the crashing,but setting to 8000 fixed it. High Five.
Re: Plugin crashes
Post by Gale Andrews » Wed Dec 02, 2015 5:07 pm
8000 is only 192 less than default.
Anyway I will say to reduce the buffer in the release notes, rather than set it to 8.
themickster
Re: Plugin crashes
Post by themickster » Wed Dec 02, 2015 6:29 pm
I saw that but the 192 made the difference.
themickster
Re: Plugin crashes
Post by themickster » Mon Jan 11, 2016 9:59 am
I spoke to a programmer about it last week. He said that the writers worked in base ten and not binary, meaning for example that 1Mb is worked out as 1000K instead of 1024. The buffer needs to be 8000, not 8192 nor anything else.
Re: Plugin crashes
Post by Gale Andrews » Mon Jan 11, 2016 11:47 am
themickster wrote:I spoke to a programmer about it last week. He said that the writers worked in base ten and not binary, meaning for example that 1Mb is worked out as 1000K instead of 1024. The buffer needs to be 8000, not 8192 nor anything else.
OK I made this suggestion in the bug report and release notes. I still find 8 almost as safe myself, but 9 crashes a lot.
Thanks
