Latency
jethroburns
Re: Latency
Post by jethroburns » Tue Nov 17, 2015 7:00 pm
Funnily enough, I am hardly on the phone during the day. Customers nearly always contact me by e-mail and I am constantly looking up words on the Internet.
Re: Latency
Post by Gale Andrews » Wed Nov 18, 2015 1:45 am
jethroburns wrote:Well, the strange thing is, I can record sound from the click track or the Internet when WASAPI is enabled but I have to turn it back to MME to record myself and my instruments!
Is that the same as:
jethroburns wrote:I think my laptop has Vista but it still has MME and will not record me if I use (bear with me I might spell this wrong) WASAPI instead of MME
Is the problem "error opening sound device" or something else?
Audacity's WASAPI support is not fully finished, especially for recording from physical inputs. And as Steve implied, WASAPI is less compatible with all sound devices than MME.
You could see if anything here helped: http://wiki.audacityteam.org/wiki/Relea ... 1.1#wasapi.
jethroburns
Re: Latency
Post by jethroburns » Wed Nov 18, 2015 2:10 am
Thanks for your answer, Gale.
The question I asked yesterday was about not being able to record the click track so as to adjust the latency.
Today I managed to figure out how to make it work
( I went into Edit, preferences, devices and changed MME to WASAPI and then (for the "recording" box at the bottom) I changed Scarlett in (Scarlett is my interface appliance) to Scarlett out). I can now record my click track.).
However, I had to return to the original setting to be able to record me singing and playing instruments.
Thanks for your link but I have to say, at first sight, it looks a bit too technical for me. But thanks anyway.
Anton
