Windows 7 - Audacity - No Infrasound EQ
Sam Houston
Post by Sam Houston » Sat Nov 14, 2015 9:46 pm
In the past I've seen an Audacity No Infrasound EQ but I can't find it now. Any help?
Also I'm using Windows 7 and can't seem to access Users/AppData. If I find the Eq, where do I save it?
Trebor
Re: Windows 7 - Audacity - No Infrasound EQ
Post by Trebor » Sat Nov 14, 2015 10:28 pm
Sam Houston wrote:In the past I've seen an Audacity No Infrasound EQ
"No Infrasound" was my name for a high-pass filter, ( a/k/a/ bass roll-off), which removes inaudible infrasound.
Sam Houston wrote:,,, I can't find it now. Any help?
For some reason my "No Infrasound" post is off limits at the moment ... http://forum.audacityteam.org/viewtopic ... 80#p234980
However you can see how to re-create such an equalization here ... http://forum.audacityteam.org/viewtopic ... 79#p227379
Sam Houston wrote: I'm using Windows 7 and can't seem to access Users/AppData. If I find the Eq, where do I save it?
"AppData" is a hidden folder in Windows , but you don't need to make it visible to save an EQ-curve you've created , or imported , that can all be done within Audacity's equalizer, see "Manage Curves" here ...
http://manual.audacityteam.org/o/man/eq ... tml#manage
Post by Gale Andrews » Sat Nov 14, 2015 11:55 pm
Trebor wrote:For some reason my "No Infrasound" post is off limits at the moment ...
It was in a group of topics that were (if I recall) in a now closed board called "The Lounge" which became a rag tag place where most toipics really belonged somewhere else.
I reinstated the topic in "Audio Processing": http://forum.audacityteam.org/viewtopic ... 28&t=77121.
