Replace with silence [SOLVED]
mr2nut123
Post by mr2nut123 » Thu Oct 29, 2015 12:04 pm
I have recorded a drum track and it's perfect except for me adding an extra bass drum near the end :evil: lol. I know how to add a silent section into the recording, but i don't want to modify the length of the track by even the smallest amount for obvious sync reasons. Is there a way to drag over the particular note, and simply replace with silence? Hope that makes sense.
Re: Replace with silence
Post by steve » Thu Oct 29, 2015 12:22 pm
Click and drag over the note to select it, then "Edit menu > Remove Special > Silence Audio" (shortcut Ctrl+L)
mr2nut123
Re: Replace with silence [SOLVED]
Post by mr2nut123 » Thu Oct 29, 2015 2:50 pm
steve wrote:Click and drag over the note to select it, then "Edit menu > Remove Special > Silence Audio" (shortcut Ctrl+L)
Cheers for that! :-)
