Splitting stereo track [SOLVED]
themickster
Post by themickster » Sat Oct 24, 2015 2:51 am
What's the difference between 'Split stereo track' and 'Split stereo track to mono'? There doesn't seem to be any difference in my setup.
I'm guessing that the first one should keep the panning.
Re: Splitting stereo track
Post by kozikowski » Sat Oct 24, 2015 3:25 am
If you watch the data to the left of the tracks, Split Stereo Tracks retains the "Left" and "Right" identities of the tracks even while it's splitting them from each other.
Split To Mono give you two stand-alone Mono tracks and either of them will play to both speakers in a music system.
Scroll down.
http://manual.audacityteam.org/o/man/au ... html#panel
themickster
Re: Splitting stereo track [SOLVED]
Post by themickster » Sat Oct 24, 2015 10:04 am
Pretty obvious,put like that. Thank you. 8-)
