Adobe Audition Broadcast Limiter
Dear Users - My friend has Adobe Audition and loves the Broadcast Limiter. Can this limiter be actualized in Audacity 2.1.1? I have Windows 8.1. Here are the settings. Thank you - Tom
Re: Adobe Audition Broadcast Limiter
The current version of Audacity (2.1.1) includes a limiter. It is somewhat simpler (and easier to use) than the one in Adobe Audition.
http://manual.audacityteam.org/o/man/limiter.html
Thank you, Steve. I will check-out the link. - Tom
