Won't play through USB sound card [SOLVED]
themickster
Post by themickster » Thu Oct 08, 2015 1:55 am
I have a Soundblaster Extigy. All other software will playback through it but not Audacity.
XP
Audacity 2.1.1
Re: Won't play through USB sound card
Post by steve » Thu Oct 08, 2015 2:17 am
Check that you have it selected as the playback device in the device toolbar.
Also, please be aware of this: http://forum.audacityteam.org/viewtopic ... 46&t=84123
themickster
Post by themickster » Thu Oct 08, 2015 6:08 pm
I'll try that. Thank you.
I never take my PC online, so I'm okay with XP. I also use Record Producer, which the buyer of the company refuses to update beyond XP.
themickster
Re: Won't play through USB sound card [SOLVED]
Post by themickster » Sat Oct 10, 2015 10:53 am
That's fixed it. Thank you.
