Looping Specific Part of Track
coolitic
Post by coolitic » Wed Oct 07, 2015 11:51 pm
I know how to loop complete tracks, but I am trying to find a way to loop so that it goes back to a certain point (eg: loop back to the 15 second mark) rather than the start of the track.
Re: Looping Specific Part of Track
Post by steve » Thu Oct 08, 2015 12:46 am
If you want that as a part of the recording, use the "Repeat" effect: http://manual.audacityteam.org/o/man/repeat.html
If you want to loop it just so that you can hear it (but not part of the project), then use "Loop Quick Play" in the Timeline: http://manual.audacityteam.org/o/man/timeline.html#tqp
coolitic
Post by coolitic » Thu Oct 08, 2015 9:05 pm
Hmm, I did not mean to loop it by adding redundant tracks.
Based on your response, it seems what I am trying to achieve would be player-specific and not something achievable in audacity.
Post by steve » Thu Oct 08, 2015 11:19 pm
coolitic wrote: it seems what I am trying to achieve would be player-specific and not something achievable in audacity.
Perhaps you could try and explain, in more words, exactly what you are trying to accomplish.
coolitic
Post by coolitic » Fri Oct 09, 2015 1:37 am
I don't want to copy looped parts of the track over and over again. I want the player to go back to a certain interval every time it reaches the end. Copying looped sections is not an efficient method when the player can just loop back to a certain interval.
Post by steve » Fri Oct 09, 2015 1:44 am
Hold the shift key down and press the Play button.
See "Loop play": http://manual.audacityteam.org/o/man/tr ... .html#play
coolitic
Post by coolitic » Fri Oct 09, 2015 8:35 pm
No i meant while im playing it outside of audacity.
Post by steve » Sat Oct 10, 2015 1:53 pm
coolitic wrote:No i meant while im playing it outside of audacity.
Does the player that you are using outside of Audacity do "loop play"?
coolitic
Post by coolitic » Sat Oct 10, 2015 3:12 pm
yes, but winamp goes to the start of the track and I would like it to go to a specific time interval instead.
Post by steve » Sat Oct 10, 2015 5:08 pm
Audacity does not support loop points in exported files.
Even if it did, I don't think that WinAmp supports loop points in files either (though I could be wrong about that).
