effects pane
effects pane
removing vocals and keeping the bottom end of a file requires "inverter" in the effects window, however only invert is available... How do I get Inverter?
Re: effects pane
For removing vocals using the current Audacity 2.1.1, please see here: http://manual.audacityteam.org/o/man/tu ... ation.html
