Can we make autotune more lifelike?
themickster
Is there a way to lessen the sqeakiness of man to woman autotune?
Re: Can we make autotune more lifelike?
There's a free [windows] plugin called RoVee which does male-to-female ...
Voice conversions are difficult because not all sounds change. Yes, most of the tones go up, but some don't go up as much and some like "s" and vocal tick sounds don't change at all. That's why simple pitch changes more than a note or two sound funny.
themickster
Thank you, Together.
