acidized wav
webbcity01
acidized wav
Post by webbcity01 » Wed Sep 23, 2015 4:23 pm
Hi:
I have windows 7 and audacity 2.0.6. Will I be able to import acidized wav files? Thank you!
Re: acidized wav
Post by steve » Wed Sep 23, 2015 4:38 pm
The current version of Audacity is 2.1.1 and is available here: http://web.audacityteam.org/download/windows
I think that Audacity should be able to import acidized WAV files, but it will not recognise the loop points or any other proprietary acid data.
