I'm stupid. I know there is a simple answer, but I am unable to play just one pair of audio tracks. It plays all track together. Kinda noisy. Thanks for someones help.
GW
Playback
Re: Playback
If you export the performance it will do that, too.
Use the MUTE and SOLO buttons to the left of each track.
Re: Playback
The "Mute" and "Solo" buttons are in the "track information panel" ("track control panel") http://manual.audacityteam.org/o/man/au ... html#panel
The behaviour of the "Solo" button has two options that can be set in preferences - I prefer the "Simple" behaviour, but the other option ("Standard") is the default. http://manual.audacityteam.org/o/man/tr ... ences.html
