hi
I want to use audacity for copying non commercial cds..how can I do that with audacity??I TRIED TO DO THAT BUT IT SEEMS TO BE COMPLICATED..
LENNY
copying cds..
Re: copying cds..
It does, yes. There is no "copy CD" unless you have a stand-alone player which can do that. The process is to "rip" the show from the original CD and burn it onto a new blank CD. Two separate steps. Audacity won't do any of those things. Audacity can edit and change the show between the two steps, but it won't rip or burn.IT SEEMS TO BE COMPLICATED..
Re: copying cds..
Thanks
