Exporting pitch with respect to time to Excel file
TegGagen
Post by TegGagen » Mon Sep 14, 2015 3:40 am
I know there was a post on http://forum.audacityteam.org/viewtopic.php?f=28&t=4559, and they made it seem complex (probably is). Is there any way of having pitch data export to something like this:
Time (s) | Pitch (Hz)
1 400
2 600
3 440
4 880
5 700
6 700
If there is, how would I do this? If not, is there any open source program that you know of that would work?
Re: Exporting pitch with respect to time to Excel file
Post by Gale Andrews » Mon Sep 14, 2015 2:08 pm
TegGagen wrote:I know there was a post on http://forum.audacityteam.org/viewtopic.php?f=28&t=4559, and they made it seem complex (probably is). Is there any way of having pitch data export to something like this:
1 400
2 600
3 440
4 880
5 700
6 700
Do you actually have one-second-long blocks of sine tones? Otherwise, what about the complexities of key signature or pitch detection in a piece of complex music, before we get to exporting it as data?
If you use Analyze > Plot Spectrum..., and choose an "Autocorrelation" choice or the "Cepstrum" choice you can export a text file containing columns for "Lag", "Frequency" and "Level". "Enhanced Autocorrelation" is probably the best choice for Pitch determination. That is all I know of, unless there are Nyquist Prompt methods.
TegGagen wrote:If not, is there any open source program that you know of that would work?
It depends what your actual goal is. I don't use it, but Sonic Visualiser has some export features.
TegGagen
Post by TegGagen » Tue Sep 15, 2015 2:51 pm
Thanks, that works.
Post by Gale Andrews » Wed Sep 16, 2015 12:53 am
TegGagen wrote:Thanks, that works.
Which, Sonic Visualizer? Clear feedback from you may help other users reading this. ;)
