Equalizer range
Re: Equalizer range
Post by steve » Sat Sep 24, 2016 5:23 pm
You've still not told us what you are trying to do and why you need to process frequencies above 20 kHz. If you tell us that, we may be able to suggest a workaround/
DVDdoug
Forum Crew
Re: Equalizer range
Post by DVDdoug » Sat Sep 24, 2016 5:24 pm
Steve's answer is the truth. Audacity is an audio editor.
