is there a way to bump up volume equally automatically?
themickster
Re: is there a way to bump up volume equally automatically?
Post by themickster » Fri Sep 25, 2015 9:49 pm
I had the same problem with a vox track. I solved it by selecting only the louder bits for compression, then boosting the whole lot to the level I wanted.
calvin_0
Post by calvin_0 » Mon Oct 05, 2015 11:19 pm
steve wrote:Amplify the track with default settings before you apply the compressor. That will (mostly) prevent the compressor from making the loudest parts louder. You can amplify the track to a lower level later if you wish.
I would NOT recommend using the Leveller effect because it creates distortion.
cant believe i never though of that *facepalm myself*
it works.. thanks. now i dont have to spend all day combing through hours of audio
